Would a windshield created out of Borosilicate float glass be stronger than a typical windshield?
scottf200
Western NC
X; immed family 3 & Y
An inteview with Tesla folks mentioned this: Borosilicate float glass. I asked the Bard LLM.
Q: Would a windshield created out of Borosilicate float glass be stronger than a typical windshield?
A: Yes, a windshield created out of Borosilicate float glass would be stronger than a typical windshield made of tempered glass in some aspects, but weaker in others. Here's a breakdown:
Strengths of Borosilicate float glass:
  • Higher impact resistance: Borosilicate glass is significantly more resistant to impact than tempered glass. This means it is less likely to crack or shatter when struck by objects, such as rocks or debris.
  • Greater thermal stability: Borosilicate glass has a higher coefficient of thermal expansion, which means it can withstand wider temperature fluctuations without cracking or breaking. This is important for a windshield, as it is exposed to a wide range of temperatures throughout the year.
  • Better chemical resistance: Borosilicate glass is more resistant to chemical etching than tempered glass. This is important for a windshield, as it is exposed to rain, snow, and other chemicals that can cause the glass to deteriorate over time.
  • Improved scratch resistance: Borosilicate glass is harder than tempered glass, making it more resistant to scratches and abrasions.
Weaknesses of Borosilicate float glass:
  • Lower optical clarity: Borosilicate glass is not as optically clear as tempered glass. This means that objects seen through a borosilicate glass windshield may appear slightly distorted.
  • Higher cost: Borosilicate glass is more expensive to manufacture than tempered glass. This means that a windshield made of borosilicate glass would be more expensive than a typical windshield.
  • Heavier weight: Borosilicate glass is heavier than tempered glass. This could have a negative impact on the fuel efficiency of a vehicle.
Overall:
While Borosilicate float glass offers several advantages over tempered glass in terms of impact resistance, thermal stability, and chemical resistance, it is also less optically clear and more expensive. The decision of whether to use Borosilicate float glass for a windshield would depend on the specific needs and priorities of the vehicle owner.
Here are some additional factors to consider:
  • Type of vehicle: Borosilicate glass may be more beneficial for vehicles that are frequently used off-road or in harsh environments.
  • Driving conditions: Borosilicate glass may be more suitable for drivers who live in areas with extreme weather conditions.
  • Personal preferences: Some drivers may prefer the clarity of tempered glass, while others may be willing to sacrifice some clarity for the added strength and durability of borosilicate glass.
Ultimately, the decision of whether to use Borosilicate float glass for a windshield is a personal one. There are pros and cons to consider, and the best choice will depend on the individual's specific needs and priorities.
Bard LLM
Q: What was the source for the last answer?
A: The information in my previous answer about Borosilicate float glass for windshields was gathered from a variety of sources, including:
Technical resources:
Articles and studies:
Additional sources:
MiguelAznar
Miguel
Cybertruck 3-motor
Laboratory beakers are made of borosilicate glass, so it is tough. I just looked up borosilicate float glass and found a couple references to it being even more abrasion resistant than borosilicate glass. I would be very happy with a laboratory grade windshield! We will be able to fill our windshield washer reservoir with boiling acid ?
scottf200
scottf200
Western NC
Thanks for that clue. I didn't know the difference so I had to ask.
It seems that "optical clarity" is a major difference ... good for windshields.
I recall my first X ('16 Sig P90DL) windshield and it had double vision at night with street lights, headlights, etc. They replaced it once and it was a little better.
My current X ('17 100D) is much better.
Q: What is the difference between borosilicate glass and borosilicate float glass
A: While both borosilicate glass and borosilicate float glass share the same basic properties, there are some key differences between them:
Borosilicate glass:
  • Production process: Borosilicate glass is traditionally produced through a melting and forming process, which involves heating a mixture of silica, boric oxide, and other additives to high temperatures and then shaping it into the desired form. This process can be more complex and costly than the float glass process.
  • Properties: Borosilicate glass is known for its high resistance to thermal shock, meaning it can withstand sudden changes in temperature without cracking or breaking. It also has excellent chemical resistance and is highly scratch-resistant. However, it is not as optically clear as other types of glass and can be more expensive.
  • Applications: Borosilicate glass is commonly used in laboratory glassware, cookware, and high-performance lighting due to its excellent thermal and chemical properties.
[Cybertruck] Borosilicate float glass:
  • Production process: Borosilicate float glass is produced through the float glass process, which involves floating molten glass on a bed of molten tin. This process creates a smooth, flat surface with minimal distortion.
  • Properties: Borosilicate float glass shares many of the same properties as borosilicate glass, such as high thermal resistance and chemical stability. However, it may not be as strong or scratch-resistant as borosilicate glass produced through traditional methods, and it may have slightly higher optical distortion.
  • Applications: Borosilicate float glass is often used in architectural applications, such as windows and doors, due to its combination of strength, durability, and optical clarity. It is also used in some high-end consumer products, such as cooktops and ovens.
Here's a table summarizing the key differences:
FeatureBorosilicate GlassBorosilicate Float Glass
Production processMelting and formingFloat glass
PropertiesHigher thermal shock resistance, excellent chemical resistance, high scratch resistanceHigh thermal resistance, good chemical resistance, good scratch resistance, good optical clarity
ApplicationsLaboratory glassware, cookware, high-performance lightingArchitectural applications (windows, doors), high-end consumer products (cooktops, ovens)
Ultimately, the choice between borosilicate glass and borosilicate float glass depends on the specific application. If thermal shock resistance and chemical resistance are the top priorities, then borosilicate glass may be the better choice. However, if optical clarity is important, then borosilicate float glass may be a more suitable option.
Dazureus
US
'21 Model Y, '24 Cyberbeast
I haven't had a major chip or crack in my Model X windshield in the 7 years I've owned it and I live a few miles south of an active gravel pit. I do have lots of tiny sandblasted chips though. Also, the early Model X windshields also had an issue with ghosting headlights from oncoming vehicles. It's just a minor annoyance and I'm not sure if this was a glass composition issue or angle, but hopefully this will be overcome if it hasn't already been.
scottf200
scottf200
Western NC
FYI, my '17 X glass is *way* better than my '16 X glass was (even the replacement).
I do have a rock chip in my '17 X glass. My auto insurance company gave me the option of trying to have it filled (pressure injection) and could still later have it replaced. It is in the middle between driver and passenger and 9" high so while it is still easily noticeable it does not bother me.
Deleted member 17810
Guest
It would shred whoever is in the cabin if it breaks.
It's super sharp shards.
scottf200
scottf200
Western NC
I don't understand your comment and you didn't quote anything in particular.
We are talking about tempered glass with an inner layer (PVB or Polyvinyl Butyral) that binds the two glass layers together, preventing them from shattering into large, dangerous pieces when they break.
Planet Earth
$59k CT delivered 6/26/26
I wonder if the glass is the exact same formulation as the Semi windshield glass.
Mrp911
Vista Ca
Model 3, CyberBeast Vin164
I have replaced my Model3 windshield 3 times for rock chips which grew quickly before I could super glue fix them. Definitely not very tough. The last one was $1400. Can only imagine what the CT windshield would cost to be replaced.
unless you had to replace one!
:ROFLMAO:
Tesla Cybertruck Would a windshield created out of Borosilicate float glass be stronger than a typical windshield? 1702013971551
Borosilicate is like 10x the price of tempered glass
and while it’s hard, I think it’s also brittle, and the lack of optical clarity a problem for Teslas in particular (with optical sensors)
Planet Earth
:ROFLMAO:
I‘m sure that’s the reason why only 15% of the glass is made with borosilicate.
Gordon_M
Gordon
Aberdeen Scotland
Tri-Motor FSD
Oilfield equipment Inspector
Agreed, it's not when it breaks, as any glass would do eventually, it is whether the resulting shards as sharp and a danger to life. Don't assume laminating it with Polyvinylbutyl would render it safe.
