Cybertruck spots/corrosion
agordon117
Ohio
cybertruck foundation awd
Did you clean the BKF off with something after? Soap and water or denatured alcohol?
Just want to be sure you aren't leaving any on the surface (you aren't supposed to let it sit)
Let us know if they come back at all.
Barkeeper's Friend says to rinse with water.
And yeah, I second that. We need to know if it's inherent in the metal or if it's just surface marring from some alkaline contaminant.
vertigo3pc
vertigo3pc
Will
Los Angeles, CA
turo.com
Cybertruck AWD FS, Model X, Model Y
Cleaned it off with denatured alcohol, looks great now that it's dried out a bit.
I'll keep an eye on it overnight.
Dude, that stuff is alcohol with poison in it. I don't know how it's legal; it's worse to breathe than alcohol, still flammable, and leaves a toxic residue.
Also a bit overkill for something water soluble ^-^;
vertigo3pc
vertigo3pc
Will
Los Angeles, CA
turo.com
vertigo3pc
vertigo3pc
Will
Los Angeles, CA
turo.com
Chemical Guys Iron Decon spray was applied and left to work. No purple residue or anything indicating any remaining contamination was present.
Wonder if Tesla is aware of how to clean their own CT when it arrives at a service center for delivery. Barkeeper's Friend to clean it off, water to rinse, and windex to restore the shine seems to be pretty straightforward, and no iron contamination left behind that I could get to present with the Iron Decon spray.
ProtectaClear
Jackie
Rancho Cordova, CA
S
I received my AWD Cybertruck on February 1, 2024. Throughout the LA rain, I noticed the corrosion was forming on the metal like other people have noted, so I decided to start documenting it and bringing it to Tesla's attention. I figured it was already on their radar, but I want it attended to under the warranty. So I made a service appointment for this morning.
The truck was taken to the back and the exterior was washed, just to verify the corrosion was not specks of dirt.
Speaking with someone at the facility, they told me 1) they have a procedure/guidance for how to fix it, but 2) they don't have the tools on hand, nor have they done this repair before. They documented the corrosion, and told me they'll give me a call next month when the tools have arrived and they can perform the service/repair.
The Cybertruck has 381 miles on it, and has spent much of the 11 days in my custody parked in front of my house. Cold weather, rain, and some direct sunlight later, I attached a few photos of the corrosion spots and a video. Seems like it's much more prominent on the top metal that rises above the truck bed moreso than anywhere else, but the spots are definitely everywhere in the metal.
Pardon my gross hands and fading nail polish...
We tested BKF More (liquid), then Windex, which neutralizes the BFK, it removed a couple spots like this. These look a bit darker, but worth a try and won't compromise anything Tesla is going to do.
I am curious as to what their process will be, if you find out, please share!
vertigo3pc
vertigo3pc
Will
Los Angeles, CA
turo.com
I definitely will. I want to see what Tesla intends as their "final fix" before I try the ProtectaClear. However, the BKF "Soft" (liquid), then water, then Windex cleaned it up really well.
Raxar
Max
I used BKF for the spots on my cybertruck and it seemed like at first they went away but I am noticing they’re still there now the next day, really weird.
DMC-81
Dana
Transformers Camaro SS, C8 Corvette Z51, Dodge Magnum R/T, 1981 DeLorean
Barkeeper's Friend when used properly is great. Here’s some advice on stainless steel maintenance from the DeLorean Club of Florida pulled from other threads:
Rail dust and other contaminants:
#29
Using Barkeepers Friend:
#15
#5
Washing and Cleaning Fingerprints:
#40
Don’t Use Windex and other advice
#13
#18
#24
#45
cbertgo
Colbert
Roanoke, VA
CyberBeast-tri-motor
Have you tried an application of Bar keeper friend polish and spray afterwards with windex?
Deleted member 8371
Guest
I do not want to wash it all the time, that's why I picked SS. It is made up of metals in it, chrome is one that helps stop corrosion. Maybe they put less in so they could bend without cracking. Just a thought. Just a thought.
carsly
Vin
Princeton, NJ
LR Defender, CT AWD
There is a long-proven solution to prevent corrosion on vehicles like this...
....it's called....
....PAINT
Seriously. If they want to maintain the look, and don't have quite the right formulation down on the HFS, then spray on 3 coats of clearcoat, no color layers, before shipping and call it a day.
