14-50R Outlet Neutral Bonding
znowstorm
Ontario Canada
Model S
I have searched online, forums and the official Cybertruck manual and cannot find the asnwer to this simple but important question...
Is the neutral line on the 14-50R outlet bonded to ground within the Cybertruck or not?
This question is important because one of the uses for the Cybertruck outlet is to power loads in a house in a temporary power outage. A straight forward way to do this is through a generator input plug connected an interlocked breaker at the main panel. The physical interlock prevents the panel from being powered by the grid and generator at the same time.
The issue of neutral bonding in the Cybertruck 14-50r is important because we can only have a single neutral to ground bond in the system. There is already one in the home's main panel. If the Cybertruck is bonded, then it would cause a problem and won't work. This would require a more complex and costly work around such as re-routing the main panel through a neutral breaking manual transfer switch. If the cybertruck's outlet is not already bonded however, then you can just plug it in to a generator input plug, and in the other use cases where bonding is required, can be easily done via bonding plug.
One can check if the neutral is bonded to ground by measuring electrical conductivity between the neutral and ground pin. If there is no resistence, then it is bonded. But if there is high or infinite resistance then it is not bonded. This is most accurate when the outlet is on (but please make sure you are not testing the hot pins that way), in case there is some internal rely that makes the bond only when the plug is active.
scottf200
Western NC
X; immed family 3 & Y
My response from your TMC that talks about the test in a slightly different way.
The common test is:
But to be thorough, testing with a multimeter seems necessary. Here's a step-by-step idea:
1. Ensure the Cybertruck's NEMA 14-50 outlet is active (providing power).
2. Use a multimeter to measure voltage between the neutral and ground prongs on the outlet.
3. If the voltage is close to 0V, the neutral is bonded to ground in the inverter.
4. If there's a voltage (around 120V), the neutral is floating.
Yep, not connected while off, but N and G are both 120V to phase (and 0 to each other) when outlets are on. So likely internal relay.
cybercricket
Why wouldn't it work ? What's the problem ?
Btw, single place (main panel) for bonding ground to neutral has more to do with the branch circuits as opposed to supply - to keep the ground wire free of the return currents.
znowstorm
Ontario Canada
Model S
I am not an electrician, but was told that it would cause problems if there was more than a single neutral to ground bonding points in a system, that's why if you have multiple panels and sub-panels, only one of them would be bonded. I am not 100% sure why it would cause a problem, only that it would.
Did anyone try to wire the 14-50r to a generator input plug that is connected to a home panel? Any issues with GFCI circults? Does the Cybertruck detect a fault and shut the outlet down (I heard the lightning F150 shuts down when it detects another ond due to current flowing back through ground line)
Did anyone try to measure resistance between Neutral and Ground when the outlet is activated to see if there is resistance? The fact that it is not connected while off is a good sign. I wonder if it is connected while on? If it is a rely that connects it, then perhaps there is a way to control that relay.
cybercricket
Okay, so you're missing the context there. Like I said earlier that's indeed a safety problem for the branch circuits coming out of the sub-panels as then they get no clean path to the ground. From the supply end that is not an issue. In fact a standard home supplied by a transformer will have the neutral bonded in two places - at the transformer where neutral originates, and then once again at the service entrance (main panel).
It "works" but isn't code. Don't want current lifting EGC potential.
Generators need the neutral-ground shorting jumper removed when feeding a house. Otherwise, the generator frame sits at a potential determined by the current in the neutral and the parralel resistance of the ground and neutral wires in the cable. Or in this case, the body of Cybertruck. Another reason Powershare is better.
Yep, people have done that. Pretty sure Cybertruck has GFCI/ leakage monitoring.
There is some (sub 1 V) voltage offset so resistance checks don't work.
Relay would be open for Powershare.
On the house side, the neutral is bonded to ECG and earthing electrodes only at the service entrance/ disconnect. The transformer has a local ground also but there is no ground wire running back to the transformer.
If there were a ground rod on the generator/ truck, it would be less of an issue since that would establish a local equipotential region.
scottf200
Western NC
FYI, this was helpful to me so I thought I'd share the LLM output.
EGC Potential Rise: "EGC" stands for Equipment Grounding Conductor. If current is flowing through the ground wire, it can cause the voltage of the ground wire to rise above zero. This is dangerous because it means that metal parts of appliances or equipment that are supposed to be grounded for safety could become energized.
Break down the concept of **electrical potential** and why it’s critical for the **ground wire** and **neutral wire** to remain at the same potential for safety.
### 1. **What is Electrical Potential?**
  • - **Electrical potential** (often just called "potential") refers to the **voltage** at a specific point in a circuit, measured relative to a reference point (usually the ground).
  • - Think of it like water pressure in a pipe: voltage is the "pressure" that pushes electrical current through a circuit.
### 2. **Neutral and Ground Wires**
- **Neutral Wire:**
  • - The neutral wire is part of the circuit that carries current back to the source (e.g., the utility transformer) in a normal operating condition.
  • - It is typically at or near **0 volts** relative to the ground because it is connected to the earth at the main service panel.
- **Ground Wire:**
  • - The ground wire is a safety wire that provides a path for current to flow to the earth in the event of a fault (e.g., a short circuit).
  • - It is not intended to carry current under normal conditions.
### 3. **Why Neutral and Ground Must Be at the Same Potential**
  • - The neutral and ground wires are **bonded** (connected) at the **main service panel**. This bonding ensures that:
  • - The neutral wire is at the same voltage (potential) as the ground wire.
  • - The ground wire remains at **0 volts** relative to the earth, which is critical for safety.
### 4. **What Happens if Neutral and Ground Are Not at the Same Potential?**
If the neutral and ground wires are not at the same potential (e.g., due to multiple neutral-to-ground bonds or a fault), several dangerous situations can arise:
#### a) **Shock Hazard**
  • - If the ground wire is not at **0 volts**, it can become energized. For example:
  • - If a fault occurs in an appliance, current could flow through the ground wire.
  • - If the ground wire is not properly bonded to the neutral, it could remain at a higher voltage, creating a shock hazard if someone touches a grounded object (e.g., a metal appliance case).
#### b) **Current on the Ground Wire**
  • - The ground wire is not designed to carry current under normal conditions. If current flows through the ground wire due to a voltage difference between neutral and ground, it can:
  • - Overheat the ground wire, creating a fire hazard.
  • - Cause ground loops, which can interfere with sensitive electronics.
#### c) **Improper Operation of Circuit Breakers**
  • - Circuit breakers and ground fault circuit interrupters (GFCIs) rely on the neutral and ground being at the same potential to function correctly. If they are not, these devices may not trip during a fault, leaving the system unprotected.
### 5. **Example Scenario**
Imagine you have a home electrical system with two neutral-to-ground bonds:
  • - One in the **main service panel** (correct).
  • - One in a **subpanel** or a **generator** (incorrect).
If a fault occurs in an appliance connected to the subpanel:
  • - Current flows through the neutral wire back to the subpanel.
  • - Because of the second neutral-to-ground bond in the subpanel, some of this current also flows through the ground wire.
  • - The ground wire is now carrying current, which raises its voltage above **0 volts**.
  • - If you touch a grounded object (e.g., a metal pipe or appliance case), you could receive a shock because the ground wire is no longer at **0 volts**.
### 6. **Why Bonding at One Point is Critical**
- By bonding the neutral and ground wires **only at the main service panel**, we ensure:
  • - The ground wire remains at **0 volts** relative to the earth.
  • - Current flows only through the neutral wire under normal conditions.
  • - The ground wire provides a safe path for fault current, protecting people and equipment.
### 7. **Key Takeaway**
The phrase **"This ensures that the ground wire remains at the same potential as the neutral wire, which is critical for safety"** means:
  • - The neutral and ground wires must be at the **same voltage (0 volts)** to prevent shock hazards, ensure proper operation of safety devices, and avoid current flowing through the ground wire.
  • - This is achieved by bonding the neutral and ground wires **only at the main service panel** and ensuring no other bonds exist in the system.
znowstorm
Ontario Canada
Model S
Ok, so multiple neutral and ground connection is bad, say one at the main panel, and another at the Cybertruck. Do we know that Cybertruck has neutral and ground from the 14-50 outlet bonded?
If Cybertruck's 14-50 outlet doesn't have neutral bonded to ground, then amazing. For application that needs bonding, one can just use a bonding plug. Simple and good.
If Cybertruck's 14-50 outlet has neutral bonded, how bad is it? Say it is wired to the main service panel using a 20 feet long 8/3 wire, and there is also another neutral to ground bond in the main service panel.
It is not permanently bonded. It is likely that it has an internal relay to connect them when in outlet mode and disconnect them when backing up a house via Powershare.
Worst case 40Amps of imbalanced neutral load * 20 feet of 8 neutral 8 ground (ignoring connectors) would put the truck at (0.641mOhm/ft*20ft)/2*40 = 0.256 V above ground ignoring connectors.
When it can be a bigger issue is if there is a fault and hundreds of amps flow. No touchy truck at that instant.
cybercricket
Is the ground pin on 14-50 actually connected to the chassis ?
I'm also wondering if possibly they have a sense logic - if they detect a connection between the ground and neutral before the output is enabled, they could leave the bonding relay open.
znowstorm
Ontario Canada
Model S
40A of imbalanced load is improbable as it implies that everything is flowing through the ground and nothing through the neutral at max power. The likely worse case is 20A when power is evenly split between Neutral and Ground.
The issue with the double bond, one in the panel and one in the truck is that when the current returns from the load (at the home side), it would return to the home panel via the home neutral as usual. At which point now there is 2 paths to the cybertruck, one through neutral as intended, and another through the ground (since it is joined to the neutral at both ends). About 50% of the current can flow through that ground wire. However, I don't see what issue that would cause. As long as that ground wire connecting Cybertruck and neutral is of the same size, and the bond in the panel can handle 20A, the current should not be an issue. There can be a voltage induced on the ground line but it should be small given the low resistance of the wire and max 20A current on the ground line. If there is a fault, a lot more current would flow through the ground between truck and panel, but then the breaker at the main panel should trip on the branch first before the wire burns. It is possible that the split between neutral and ground on the gen input breaker may hinder its operation. Am I missing something, under what situation is the current flow through the ground wire between the truck and panel an issue? Even if 20A flows?
A possible solution is to not connect the ground between the truck and the panel, this would prevent the split current. What sort of danger would this cause? Given that the neutral and ground is still connected at the home panel, a fault in the branch circuit would still flow through the ground back to neutral and trip the branch breaker. A fault at the truck side would still short the shell to ground to neutral through the truck's bond and trip whatever breaker there is. Is that a solution?
Powershare mode doesn't even use the 14-50 receptacle as far as I understand, it uses the charge port right? Did anyone actually measure and confirm that the 14-50 has neutral bonded to ground when in operation? I wonder if there is a way to disable the relay, or better yet, have Tesla give us explicit control of that.
Tesla Cybertruck 14-50R Outlet Neutral Bonding 2 ground neutral bond
Can I use that instead of Sentry Mode ?
znowstorm
Ontario Canada
Model S
Based on my understanding above, even in the worse case situation where we are pulling 40A from the Cybertruck all on a single 120V rail, the return current would be split on the ground and netural wire only between the home panel and the Cybertruck. Roughly 60/40, with neutral wire carrying more due to larger size. The resultant voltage rise on the ground connection at the panel is only about 0.15V (ignoring connector losses), which isn't very much to be a problem at all.
As long as the Cybertruck's outlet is GFCI and don't shut off it it sense an imbalance, I don't see why this is such a big deal. Am I missing something?
