I don't understand that. The only thing I know is that solar panels create DC current and the microinverters convert it to AC. I would add more panels and each panel has its own microinverter. I believe I currently produce a little more power than I need so I would install heat pumps first and see how many more panels I would need. After running them for a little while. Also I want to install cold climate heat pumps because the regular heat pumps use an electric element to directly heat the air, which requires a humidifier.
The Powerwall 3 allows a DC coupled system which wastes less solar energy (97.5% solar to home/grid efficiency). Each Powerwall can connect directly to 20 kW of solar panels with it's 6 independent MPPT's and inverter built into the unit. Without external inverters the system design/install is a bit simpler. Here in the PNW I wanted to maximize winter production for self-reliance and the DC coupled system does that.
Solar to home is just PV->AC though. Enphase micro inverters have equivalent 97.5% conversion efficency when powering a house.
The gain is in PV time shifting. PW3 has 89% efficency PV->battery->home.
Powerwall + (AC coupled) had 90% for AC->battery->home, but when adding in PV, PW Plus doing PV->(AC)->batt->home would be only 87%.
PW3 also has an extra 5kW PV to battery path for max sunlight utilization.
PW+
Tesla Cybertruck Keeping Solar Panels online with Powershare during power outage AISelect_20260708_073813_Firefox
Tesla Cybertruck Keeping Solar Panels online with Powershare during power outage AISelect_20260708_075829_Firefox
PW3
Tesla Cybertruck Keeping Solar Panels online with Powershare during power outage AISelect_20260707_143928_Firefox
Patriot
Denver, CO
2020 M3, 2024 Jeep 392, 2024 FS CB
Can you please explain what you mean by this? Are you saying that you lose efficiency by adding batteries (PW) to the energy path, but doing so is what allows you to use stored energy during peak rate periods and recharge during lower rate periods, hopefully, offsetting the cost of energy losses due to the lower efficiency?
It makes sense that you lose efficiency by putting battery storage in between generation and usage. My utility company does net metering, so the grid is my "battery", but I have no idea how efficient that whole process is. Of course, if the grid goes down, my panels are useless and I also can't time shift my generated energy to cover my peak energy periods. I would love to add Powershare, but I don't think they will let me since my solar is a prepaid lease. I inquired about Powerwall a couple of years ago, and they said "no".
PW+
PW3
Good points.
But my understanding is it's not the efficiency gain at max production (when going to battery) that is the most important to my use case, but during dark, cloudy/rainy periods when trying to eek out enough production to keep your battery charged enough to service essential loads (like in the winter). In low-light conditions where the power from an AC-coupled system can struggle to produce any useable power at all, or it can alternate between producing a small amount of power and nothing, a Powerwall can feed a constant (and very efficient) charge voltage to the batteries (or your home). This can help keep the batteries charged when AC coupled systems would struggle.
I don't have solar to save money, that's just what pays for the system over time, I have solar so our dwelling remains habitable, even if we have an extended power outage as would be the case after a major West Coast earthquake, a freak regional ice storm, unusual high wind event, or other cataclysmic event. Solar is an investment in our future in more ways than one.
Right, going from power to storage to power incurs loss. PW3 has a more efficient PV to battery to AC conversion chain than PV to AC to battery to AC.
Good points.
Interesting, I hadn't thought of the minimal power situation. The PV direct to battery system would be better at handling that.
schmo
Doug
Tesla Model S, Cybertruck AWD
Looking at the PowerShare Installation Manual, it now says that a Tesla Remote Meter is needed to add solar to the backup circuit. An earlier version of the manual also said that the solar breaker needed to be installed towards the top like right under the UWC breaker.
It appears now that solar will work fine without the meter and regardless of the position of the solar breaker.
Would anyone disagree?
I think you only need the Remote Meter if you want to monitor solar production in the app. Solar Powershare currently works without it, but the "house" load becomes "house-solar"
schmo
Doug
Thanks @mongo. I am already monitoring my solar with an eGauge. Looks like I am all set!
JohnRougeux
Elizabethtown, Kentucky
2025 Tesla Cybertruck dual motor, 2021 Tesla model Y dual motor
The current Gen 3 hit the sweet spot, sure, tech keeps improving but it's a fool's errand to wait for new technology that will almost certainly only be minor incremental upgrades. Tesla is constantly upgrading the Powerwall firmware with new features, new hardware is typically not required to take advantage of the new features that are enabled with regular software updates.
You don't have to use Tesla Power for the install, any certified solar installer can do it. I had a pick of at least three independent solar companies in my area. I'm really pleased with the performance of the system and the Silfab 440 panels in particular. The tax credit is pretty minor relative to having solar vs. not having solar. Just bite the bullet and do it!
I had to eliminate one solar company who insisted on using an AC coupled solar system.
Beyond eliminating conversion losses, a DC-coupled system simplifies design by using fewer components (fewer parts to fail) and allows for easier future expansions using DC-only expansion packs. It also enables more reliable off-grid charging and higher peak solar input than older AC-coupled solutions.
A DC system using Tesla Powerwall provides several distinct engineering and operational advantages:
  • Lower Hardware Costs & Simpler Design: By using a single inverter for both solar panels and battery storage, you require fewer balance-of-system components (such as extra voltage transformers and switchgear).
  • Enhanced Off-Grid Performance: During a grid outage, DC-coupled systems can trickle-charge the battery from the solar panels even in low-sunlight or low-input conditions. AC systems can cycle on and off constantly until solar generation exceeds total household usage.
  • Higher Solar Capacity Limits: Traditional AC-coupled systems historically restricted the amount of solar power that could be tied into the battery. Systems like the DC-coupled Powerwall 3 can handle heavy solar input (often up to 20 kW DC), making it much easier to add solar capacity without overloading inverter limits.
how can I tell if I have AC or DC solar system?
If your solar inverters are separate from your battery system and the two are connected by house wiring, it's AC.
If you have roof mounted micro inverters, it's AC
If you have Powerwall +, it's AC
If you have Powerwall 3 or another battery system that takes in the panel output directly, it's DC
If you are reading this in the voice of Jeff Foxworthy...
JohnRougeux
haha funny
so mine is ground mount, sunny boy inverters, no power walls.
Tesla Cybertruck Keeping Solar Panels online with Powershare during power outage IMG_2581
