Wind, Bearing, or Coolant Noise?
mmdotking
Round Rock TX
Would be great if this G version is a solid fix. Hope after 1000 miles or so doesn't come back.
Rippin1Gear
MJ
Seattle, WA
Foundation Cybertruck
plumber
I hopefully will have G going in next week, this is the 3rd visit for this issue. Last one they only replaced the hub.
Rippin1Gear
MJ
Seattle, WA
plumber
About to lose it with this service center in Fife, WA. Incompetent people… 3rd visit for this, last was wheel hub they replaced after hearing it. Now saying it’s normal.
Darryl2006
Darryl
Ny
Audi q5
So has anyone heard anything new on this front or gotten any satisfaction and been able to eliminate that noise? My noise seems to be getting louder even though the weather is getting warmer. It's crazy and I hate it!
QuantumGlen
Glen
Los Alamos, NM
Model 3, Model Y
Scientist
Folks, I may have figured it out. Check your fluid hose inside the big wiper blade. Mine was loose, and one little black clip was broken. The air flow comes across the vents in the wiper assembly, and the angle matters.... hence the left right difference. Make sure the hose can't catch the air stream, and is well tucked up inside.
mmdotking
Round Rock TX
But how to account for weather temp changes? When warmed up, etc., sound stops. Also, clicking on Slippery Surface setting almost eliminates it also, like an immediate flick of the switch. Would be great if just airflow, etc.
QuantumGlen
Glen
Los Alamos, NM
Model 3, Model Y
Scientist
Whenit is cold outside, the hose is harder, and makes more noise than when it is softer.
Darryl2006
Darryl
Ny
Audi q5
Well, my sound no longer goes away even in warmer temps. It's in the 70s here and still as loud as ever. I can't fathom how the sound could be caused by the wiper hose but I'm so desperate for a solution that I'll try anything
dpoll995
one of my clips for that hose is broken. i wonder if they sell them? its a poor design maybe ill try some tie wraps to secure it better to test the theory
QuantumGlen
Glen
Los Alamos, NM
Model 3, Model Y
Scientist
Try this. At 70 mph, push the wiper button once. When the blade is down, you can really hear the air turbulence. You might also see te fluid hose fluttering, just a tiny bit, in the air stream. Google "windshield wiper fluid hose loose in Cybertruck". Turns out this has been noticed before. My hose is like snake, and I think the air can catch it.
Tesla Cybertruck Wind, Bearing, or Coolant Noise? 20260505_101003
QuantumGlen
Glen
Los Alamos, NM
Model 3, Model Y
Scientist
Another great test would be to temporarily remove the whole wiper arm. If the noise is gone, the problem would be pinned down.
dpoll995
i have another idea for a test. tape over the slots instead. that should block the wind well enough to see if the noise stops. it has not been cold enough here so i cant try it yet.
