Stuck4ger
Cape Canaveral, FL
Aerospace
There’s been some discussion over the years about how hot the CT would be, both inside and out. Well the Merritt Isle. SC has another customer CT in the parking lot and I noticed that the sun’s reflection from the CT felt quite hot on my face. I then hesitantly put my hand on the hood and it was damn hot. I did the same to the black S parked next to it and it actually seemed hotter. But I knew that wouldn’t be good enough for this group so I went home and returned with my IR temp sensor and shot the temp of the panel perpendicular to the sun and replicated the same angle as best I could with black, MSM, and white Teslas parked nearby. Here are the results in degrees F:
CT = 106
Black = 144
MSM = 140
White = 107
Tesla Cybertruck Cybertruck stainless steel surface temperature vs. painted — MEASURED DATA IMG_9134
Tesla Cybertruck Cybertruck stainless steel surface temperature vs. painted — MEASURED DATA IMG_9136
Tesla Cybertruck Cybertruck stainless steel surface temperature vs. painted — MEASURED DATA IMG_9135
Tesla Cybertruck Cybertruck stainless steel surface temperature vs. painted — MEASURED DATA IMG_9138
TickTock
Phoenix, AZ
Electrical Engineer
I wonder what the emissivity factor for HFS is versus clearcoat. According to Fluke, it could be anywhere from 0.2 to 0.9 depending on the finish which will dramatically impact the accuracy of the reading. For this, I think it is probably best to use a contact/conduction type measurement.
Petertsai
Peter
44 Indian Clover Drive, 77381
Tesla S, cybertruck reservation
CT = 106
Black = 144
MSM = 140
White = 107
Emissivity of reflective surfaces has to be calibrated to sensor.
flyinglow
Rick
Sierra foothills, CA
BMW 335i, F250
CT = 106
Black = 144
MSM = 140
White = 107
Makes total sense. Cybertruck and white paint reflect heat away, which you could feel. Less heat to penetrate cab in theory but massive roof and windshield glass probably offset that. Anyone with a Cybertruck care to comment on interior temperatures vs exterior?
easytravelman
Oakland, CA
2016 Model X P90D signature
Hard money lender. real estate and crypto investor
CT = 106
Black = 144
MSM = 140
White = 107
Thank you for that effort. My initial thought was CT hotter. Great Job
DrShah
Samir
Weston, FL
Surgeon
CT = 106
Black = 144
MSM = 140
White = 107
My red Model Y gets super hot sitting outside in the Florida sun, i def need to measure it.
