- Jack
- Dec 1, 2019
- San Francisco Bay area
- Website
- www.arbor-studios.com
- Tesla Cybertruck FS AWD, Tesla Model Y LR
- Occupation
- Retired AI researcher
This is interesting but isn't the Semi a tri-motor drivetrain? And if this is incorrect for that might it not be incorrect in other ways?VIN DECODER:
https://vpic.nhtsa.dot.gov/mid/home/displayfile/fbec7f77-5e2b-4d06-b46c-267e7327c2ff
GVWR revealed:
- Cybertruck - Performance - 9,XXX pounds GVWR
- Cybertruck - Standard - 8,XXX pounds GVWR
- Compare to:
- Model X - Plaid - 6,7868 pounds GVWR
- Model S - Plaid - 5,596 pounds GVWR
- Model Y - Long Range - 5,302 pounds GVWR
- R1T - 8,532 pounds GVWR
- Lightning - 8,250lbs-8,550 pounds GVWR
- Hummer EV - 10,550 pounds GVWR
As required by law, VIN information published within 60 days of customer sales (customers in this case being internal customers).
Example for Dual Motor Cybertruck (with an x for check digit and assuming the Dual Motor Standard is Class G and the tri motor is Class H):
72GCEGEDXRA000001
Digits 1 -3: World Manufacturing Identifier
72G = Manufacturer: Tesla Inc., Vehicle Type: Truck
Digit 4: Make/Line/series
T = Tesla Semi
C = Cybertruck
Digit 5: Chassis/Cab Type
B = Day Cab
E = Truck - LHD
Digit 6: Gross Vehicle Weight Rating (GVWR)
E = Class 8 – Greater than 14968 kg. (33,001 lbs. and over)
G = Class G – Greater than 3629 kg. to 4082 kg. (8,001-9,000 lbs.)
H = Class H – Greater than 4082 kg. to 4536 kg. (9,001-10,000 lbs.)
Digit 7: Fuel Type
E = Electric
Digit 8: Motor/Drive Unit/Braking System
B = Dual Drive Rear Axle, Air Brakes (Designated for Semi)
D = Dual Motor – Standard (Designated for Cybertruck)
E = Triple Motor – Performance (Designated for Cybertruck)
Digit 9: Check Digit
To be assigned by manufacturer pursuant to 49 CFR § 565.15(c).
Digit 10: Model Year
R = 2024
Digit 11: Plant of Manufacture
N = Reno, NV
A = Austin, TX
Digits 12-17: Unique serial number
000001-999999
